Ebrake wire for 05 Suburban
By mezam · Oct 05, 2006in Vehicle Specific Wiring💬 6 posts👁️ 1,591 views
Posted Oct 05, 2006 · 02:18 UTC#1
The only exposed wire I could see near the Ebrake area was a bluish wire that ran up towards the dash interior but I can't be for certain. Can anyone verify that has the same model?
Thanks,
Meza
Posted Oct 05, 2006 · 02:18 UTC#2
test it
Posted Oct 05, 2006 · 03:41 UTC#3
with what? a voltmeter? Sorry but I am new to this. Would hate to damage any equipment. How would I test it?
Meza
Posted Oct 05, 2006 · 12:16 UTC#4
its kind of a lightish blue? Wrapped in like gray tape where it's popped into the firewall? It's also runnning by itself? IF those are true then most likely then you are looking at the parking brake wire. As for testing goes, a good multimeter is your best friend when tesing wires in a car. Just to help a little anyway.
Parking Brake lt. blue - switch or BCM, lt. blu plug, pin A7
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Posted Oct 05, 2006 · 14:31 UTC#5
you test it to see if it triggers when you engage the brake. If so, your golden
Posted Oct 06, 2006 · 05:43 UTC#6
cntrylvr79 thats the wire. Thanks for all your help peeps.
Meza
