HD presets not showing up in order?
By imracerx · Feb 09, 2009in Problems/Troubleshooting💬 7 posts👁️ 932 views
Posted Feb 09, 2009 · 21:19 UTC#1
whats the deal with the presets not showing up in order from top to bottom with the HD unit installed? all it shows when programmed is "::" or something like that. you basically have to guess what number preset a certain station is on? please tell me theres a way to fix this. If there is no way to fix this, Pioneer really sucks as this feature is really used alot. Thanks
Posted Feb 10, 2009 · 14:23 UTC#2
have you tied doing a "reset"? Ever since the 2.0 update, resetting the unit has resolved a lot of strange issues. Powering the unit off doesnt seem to fix anything. But when I press the "reset" button, that usually fixes the problem I was having. After a reset I usually have to confiure the AV inputs to use the Ipod again but that is usually the only thing I have to configure again. So far, it has kept my bluetooth settings and HD radio presets.
Dave
Posted Feb 10, 2009 · 22:58 UTC#3
ill give it a try thanks!
Posted Feb 10, 2009 · 23:06 UTC#4
didnt work!
Posted Feb 12, 2009 · 01:35 UTC#5
This has been discussed a lot in various threads but to make a long story short, you cannot identify the presets using the HD module. Known bug with the system.
Suggestions:
1. Really good memory
2. Yellow sticky
3. Pink sticky (for the girls)
4. Write or call Pioneer Tech Support (good luck with that one)
5. Wait and hope for a firmware fix (good luck with this one too)
Seriously it is a good add on but the limiting feature is the absence of identified presets. Once you are in the detail screen it is similar to a RDS feed with station ID, song and artist ID but presets are a no go.
Posted Feb 12, 2009 · 21:32 UTC#6
dont tell me its the same for sirius presets! It wont show the presets on there either. man this unit sucks! get what you pay for i guess!
Posted Feb 13, 2009 · 22:33 UTC#7
is there any fixes for this? i mean no preset info when using the HD an d Sirius? what about XM? there has to be an update fix for this no?
