I will be installing my F90BT this weekend. I need to use the mute wire for my onstar retention. I have been reading and reading and reading, and did not see a definative answer but it LOOKS like I can attach another wire where the mute wire is moved to, leaving the mure wire in tact and working properly? I am thinking about the power antenna wire since I do not have a power ant. I am going to verify it uses the same pin layout. I don't see why not, so I should be able to put it in the 4th hole between the 2 black wires and everything will be golden?
Thanks.
Brian
