caller ID when recieving call on F700bt?
By One Bad Stang · Feb 10, 2009in Problems/Troubleshooting💬 15 posts👁️ 1,767 views
Posted Feb 10, 2009 · 04:42 UTC#1
is it possible to get the callers name to display when someone is calling instead of just the phone number on the f700?? preferably without hacking the unit?? i have allready tried changing all my phone #'s to the format the unit displays incoming calls in. ex. 1-702-123-4567 and then reloaded all contacts into the avic in that format, and it still didnt work.
any help?
Tony
Posted Feb 10, 2009 · 05:48 UTC#2
Mine does it. All are in 555-555-5555 format
Posted Feb 10, 2009 · 05:51 UTC#3
is yours the f700? i had all my numbers in the 555-555-5555 format and it didnt do it. is there some sort of setting to change, because i cant find it.
is it maybe a compatability issue with my phone? its a palm treo 750.
Posted Feb 10, 2009 · 12:02 UTC#4
is yours the f700? i had all my numbers in the 555-555-5555 format and it didn't do it. is there some sort of setting to change, because i cant find it.
is it maybe a computability issue with my phone? its a palm treo 750.
This glitch does seem to be related to certain phones and the way they pass information, my iphone 3G passes numbers, but doesn't match them to the names in the address book, I'll survive :wink:
Posted Feb 10, 2009 · 14:49 UTC#5
well, that does make sense. my phone is a giant piece of crap, and i'm swapping it next month for something new anyway.
thanks for the help
Posted Feb 10, 2009 · 18:41 UTC#6
My cheap LG Rumor shows the callers name on screen, along with signal strength, and battery life.
Posted Feb 11, 2009 · 01:15 UTC#7
mine does the battery life, signal strength, and carrier name, but no caller id. :(
Posted Feb 11, 2009 · 19:28 UTC#8
Mine only shows the numbers as well. I don't get how the contacts can show names and mobile/ home/ office, but the caller ID can't.
Posted Feb 11, 2009 · 23:15 UTC#9
It's just one of those things.. it'd be nice if it worked for me, but it doesn't, at least I can use the VR to say "call andrea, home" and it calls who I want, that's far more important to me.
Posted Feb 12, 2009 · 00:42 UTC#10
If you notice, it works on outgoing calls, because the call originates from within the F-Series, so it can link the name to the number. It's the incoming calls that are screwed up, something is off on the format of the numbers, so it can't link the incoming number to a contact in the database.
Posted Feb 12, 2009 · 06:57 UTC#11
well, i'm getting a new phone in a few weeks. i'm looking at the samsung propel. hopefully that will do the trick.
Posted Feb 12, 2009 · 13:39 UTC#12
Seems like the VR should work then, but it doesn't f/ me.
Posted Feb 12, 2009 · 16:15 UTC#13
What phone are you using?
Posted Feb 12, 2009 · 20:07 UTC#14
Nokia 6230
Posted Feb 13, 2009 · 03:30 UTC#15
im using the palm treo 750. its an early production model though.
