Bluetooth connection stops working after 15 seconds. I paired my phone and it was working fine for a day or so, including phone book transfer, then I noticed that there was no AD2P(I did not know that unit does not support it). So I tried to to re-pair it, deleted profiles from phone and from head unit, after paring it stays connected for about 15 seconds and then disconnects but phone still shows connection. Going back to options and hitting connect does not work until I turn off bluetooth and then turn on from settings option in head unit, after that it connects merely for about 5 seconds and then goes out. Weird thing is phone shows some sort of bluetooth connection, could it be software problem in the unit, is there anywhere to clear out bluetooth settings? I was not messing with software when it happened, the only thing I did is grounded parking wire.
Just replying to myself: cycling power on cell phone solved the problem.
