rear camera
By gadgeeets · Oct 06, 2006in Problems/Troubleshooting💬 6 posts👁️ 1,441 views
Posted Oct 06, 2006 · 00:01 UTC#1
i need help i have a d2 hooked up to my 2002 nissan maxima, the camera works when im in reverse but when im moving forward and want to use it it has a blank screen. could someone tell me what i hooked up worng.... :cry:
Posted Oct 06, 2006 · 00:27 UTC#2
Sounds like you connected the power wire to the reverse lights. If you did, the camera would only get power when the reverse lights are on (when you have the vehicle shifted in reverse). Check the power lead. You may have to run a line from the front of the vehicle if you do not have a suitable connection in the rear.
Posted Oct 06, 2006 · 00:29 UTC#3
It sounds like you got the power for the camera from the reverse wire lights wire.
That wire will only have 12V+ and the camera will only have power when you are in reverse. You can still leave the ground in the rear of the car, but you need to find a wire that gets 12V+ when the car is on or in ACC. You can tap off of the ACC wire that goes to the D2 or you can find one in the rear of the car.
Posted Oct 06, 2006 · 00:31 UTC#4
Wow. I promise PaisanNYC's post was NOT there was I went to post :evil:
It sounds like I copied him basically word for word...
Posted Oct 06, 2006 · 00:32 UTC#5
LOL its ok. It looks like we were typing at the exact same time ;) Remember, great minds think alike!
Posted Oct 06, 2006 · 04:01 UTC#6
thanks for the info
