Australian maps on US F900BT
By jamie79 · Feb 11, 2009in Hacks/Mods💬 6 posts👁️ 918 views
Posted Feb 11, 2009 · 10:57 UTC#1
Will the same hack used for european maps on a US F900 work with australian maps? Has anyone done this before? I figure i can save around 60% by getting a US version rather than buying locally but its only worth doing if i can get the navigation working.
Posted Feb 11, 2009 · 14:29 UTC#2
Should work... hack uses a worldwide license...
Posted Feb 12, 2009 · 02:32 UTC#3
If you go this way and get it working let us know. I would interested in this too so I can put one in my wifes car. Cost me $3000AU to get the F900BT, reverse camera, steering controls and install but you do get free new maps in August. Would be a lot less if I bought it from the US.
I'm not convinced that the unit would fully functional in Australia that's why I haven't parted with my money. From the posts in the forums there seems to be hardware issues for traffic, FM radio. Also loading the maps seems like a pain. I personally had hoped that I could just copy a backup from my AU F900BT but this simplistic approach is probably flawed.
Good luck
Posted Feb 12, 2009 · 03:01 UTC#4
Good luck
Well, if you put a hacked executable on as US AVIC, you could copy maps from an Australian model, too... You are right about other issues though...
Posted Feb 12, 2009 · 04:03 UTC#5
Traffic update info does only work in Melbourne, Sydney & Brisbane via SUNA at the moment. My F900BT will only pick up SUNA in Sydney and Brisbane when the new maps come out August 2009. I suppose if you don't live in these areas it might be another thing you can take off the cons list.
Posted Feb 14, 2009 · 10:12 UTC#6
Traffic info isn't really an issue for me, I live in perth so theres no service here anyway. As for FM reception my understanding is the US version only picks up odd frequencies which all bar a couple of tourist info stations are. If some one using european maps on a US f900 could try it with australian maps that would answer alot of questions.
