SD Card HC Or No HC
By gadget35 · Feb 11, 2009in General💬 11 posts👁️ 2,083 views
Posted Feb 11, 2009 · 19:22 UTC#1
Is there any differenc in a A SD card that is HC or not ? Would assume the FSerious is slow already that there is no performance difference in faster cards.
Posted Feb 11, 2009 · 19:29 UTC#2
It will take it. Regardless of the speed of Avic why not get HC anyway?
It will be faster when you are putting files on it on your PC. But if you are putting small files on then it would not matter.
Posted Feb 11, 2009 · 20:32 UTC#3
Thanks fro re in SD issue i just had some cards that were not HC and was wondering if it was worth going out and spending money on HC card thats all.
Posted Feb 11, 2009 · 20:51 UTC#4
I think its only some older cameras that are not compatible with High compression but I use my 4 gig card in my 900bt all the time with no troubles
Posted Feb 11, 2009 · 21:10 UTC#5
I have a 4GB HC as well and the only reason I went with it is because Best Buy had them for super cheap. They were like $12 for SanDisk. A week later they were $30.
I would not spend money on HC unless you are transferring a lot of stuff back and forth.
Posted Feb 12, 2009 · 12:12 UTC#6
What is the maximum capacity on an SD card that I could use on the F700BT?
Posted Feb 12, 2009 · 15:11 UTC#7
8 gigs.
I saw a 4 gig hdhc for 5 bucks...
Keep checking bensbargains.net
Posted Feb 13, 2009 · 20:29 UTC#8
The manual says 8GB I think but I'm using a 16GB SDHC card without any problem. A little slow to load with 13GB of music but that was expected. I've seen other postings where people are using a 32GB card.
It seems with USB and SD it's kind of pot luck. I was using a 40GB 2.5" USB hard drive on my previous Pioneer HU but it doesn't work on the F700, even with external power. Go figure. Time for an Ipod.
Posted Feb 23, 2009 · 22:46 UTC#9
Can some other people post the size cards that they have used already?
Posted Feb 23, 2009 · 23:42 UTC#10
Cards i've used.
Sandisk SDHC Ultra II 8GB
Sandisk SDHC Ultra II 4GB
Sandisk SDHC Extreme III 4GB
Posted Feb 23, 2009 · 23:51 UTC#11
A-Data Class 6 - 8 Gig
Kingston Class 4 - 8 Gig
Kingston Class 4 - 16 Gig
No difference in the Class4 and Class6 for access time, F90bt is still slow as fsck reading an SD card, especially with videos
