F90BT Lighting Switch Terminal Wire Question
By TomRaz · Feb 12, 2009in Problems/Troubleshooting💬 12 posts👁️ 5,530 views
Posted Feb 12, 2009 · 02:15 UTC#1
I just ordered a F90BT and I was reading the installation manual. The Orange/White wire indicates it should go to the lighting switch terminal.
In my 2003 Corolla there are two lighting related wires
Radio Illumination Wire=Green
Stereo Dimmer Wire=White/Black
Since both wires are have some light functions which one of the 2 Corolla wires should I connect the Orange/White wire to ?
Posted Feb 12, 2009 · 02:26 UTC#2
That's the closer of the 2, Orange/White is also usually referred to in standard aftermarket harnesses as "dimmer"
The orange wire is flagged "illumination"
I'd use dimmer
Posted Feb 12, 2009 · 02:43 UTC#3
Agreed with Dianebrat, but don't button everything up until you test it first, since we don't know 100%.
Posted Feb 12, 2009 · 18:52 UTC#4
i am not sure about your car but my "illumination" wire provides the +12v when the lights are turned on. this signal will let the avic know that you turned the headlights on and will dim the display.
the "dimmer" wire runs through the resistor to ground that you use to dim the dash illumination of the whole car (and stock radio).
IMHO, you should use the illumination wire. thats what i did and it works great.
Posted Feb 12, 2009 · 18:58 UTC#5
I have two interior lights system wires ones negative and ones positive. Which one does mine connect to?
Posted Feb 12, 2009 · 19:44 UTC#6
Positive
Posted Feb 12, 2009 · 20:04 UTC#7
Thank you
Posted Feb 12, 2009 · 20:22 UTC#8
What I show for the Toyota
12v = blue/white
ground = brown
ign = gray
illumination =green
power antenna =black
LF speaker =pink +/purple-
RF = lt green+/blue-
LR = black+/yellow-
RR= red+/white-
Posted Feb 12, 2009 · 20:57 UTC#9
I dont see much of a difference from connecting the orange/white wire to power what is it supposed to do?
Posted Feb 16, 2009 · 18:33 UTC#10
I ordered the 700BT but do not want it to dim or automatically change to night mode. Can I just turn night mode on manually?
I turn my lights on even during the day for safety. So obviously I don't want to dim it during the daytime.
Posted Feb 16, 2009 · 18:54 UTC#11
Don't connect the illumination lead.
Posted Feb 16, 2009 · 19:56 UTC#12
or set equal settings for lights on and off
