i have a bmw z3 m roadster. The avic n4 fits the 1din perfectly the only problem that i had was securing it. i secured it by pulling up on the tabs that are on the sleeve. i need to get it in order to fix my keyless entry which keeps killing my battery. is there a way to remove the sleeve that is already attached to the unit. i know you can remove the trim. i have tried everything to get the radio out. it would be a lot easier if i could get the sleeve off of the unit and pull the unit right out but the sleeve still be stuck. please tell me some suggestions thanx
Posted Feb 12, 2009 · 02:37 UTC#1
