Hey all I have searched alot on this forums but I think my problem is vehicle specific. I have a 2004 Honda Civic EX Well I have more then one, I am in the process of installing the Avic 90bt and am running into problems.
First I dont know where the blue wire goes. The manual says if you have a glass antenna (which I do) connect it to the booster power control terminal? What is this I think its the little black box that was with my OEM radio is this correct? If so I hook it up to the white/red wire? The white/red should be the hot wire?
Next I have read alot about this illumination wire. Some say connect it to the 12 power outlet, but here my problem. I have 2 wires left over from the OEM radio red and red/black. These wires are for my interior light system. Is this where I want to connect them to? If so which wire do I connect the orange wire to? The hot (red/black) or the negative (red)?
My last two wires are the Lt/green and the Pink. I believe the pink wire goes to my black/orange wire under my dash (VSS) can anyone confirm this? I did a search, but my car wasnt under the one listed only the DX was.
Lastly I havent attempted to hook up the Lt/Green wire yet, but what wire does it hook up to on my hand brake? Thanks guys
