just got through updating my z1 to z3 but got a small problem. all things went well but now that i have it done and installed the maps seem to be in california and theres no real recognition of where i am. any ideas?
Z3 Update
Have you given it sufficient time to acquire GPS signal ( also check the number of satelites it "sees", in the hardware menu. )
now, after several random reboots, its giving me a hdd error with a black screen
Reimage the drive with Z3 again.
I have done my update and my z1 will not start up at all
Need more info. What updte? What does it do when you start it? Give me something to work with ![]()
I was updating my z1 into a z3. I can read the drive using my computer but when i put the drive in my avic it does nothing blank screen i have redone it 6 times still not working and downloaded z3 image about 4 times
Please describe (in detail) how you are updating your drive from Z1 to Z3.
Im using the instructions in the sticky z1 to z3. Downloaded all the virgin z3 files and restored them to the hard drive using acronis.
Did you restore all 4 partitions and the MBR at the same time and use the default options?
I think so but never used the MBR
Must mean master boot record. I'm a dumb a$$. Maybe that is my problem.
I reloaded the drive again but the avic will not do anything blank screen it will not even lock the drive
