why do my settings reset?
By 22justin · Feb 12, 2009in Problems/Troubleshooting💬 5 posts👁️ 888 views
Posted Feb 12, 2009 · 20:16 UTC#1
is this normal??? when i start my car up and the f90bt boots up, i lose my remembered FM stations, AV1 is off by default (when it should say ipod), the rear speakers always default to 'full' when i want it to be on 'subwoofer'
its such a hassle to have to change the settings everytime the system starts. ive noticed that if i turn off the car then power it back up again quickly, it retains the settings, but if the car is off more then 5 mins, i lose all my settings and have to set it all up again....
Posted Feb 12, 2009 · 20:25 UTC#2
No, it's not normal. Looks like the constant power wire is not hooked up properly...
Posted Feb 12, 2009 · 20:25 UTC#3
Double check your constant 12v connection (it's the yellow wire in the harness).
If that's hooked up right, send it back for warranty.
Posted Feb 12, 2009 · 20:25 UTC#4
Did you connect the yellow wire to a source with constant power ??????
Posted Feb 12, 2009 · 21:09 UTC#5
I have had the same issue in my SAAB 9-5.
It appears that (even though clearly is indicated otherwise) that the ACC and constant lead are switched the other way around.
Get a simple meter and find out :)
