Help with Ducatiboy circuit
By Emersonclay · Oct 06, 2006in Problems/Troubleshooting💬 7 posts👁️ 1,217 views
Posted Oct 06, 2006 · 19:56 UTC#1
First off, another happy customer.. dude is brillant..
but
After i installed my circuit, a really weird road noise/engine accel noise/humm/buzz (to the accel of the engine) has started.. i am not sure if this is because of the circuit, or maybe something else... any ideas what i should check??
Also... another thing i have noticed... sometimes, when i shut down/turn off the car.. my overhead lights stay on... almost like the car door is stuck open.. also the AVIC stays in the TILTED position (does not retract back in... almost like it thinks its still on, but has no power).. i had to turn the car on, turn it off, then just put it in on position.. then finally it worked (lights shut off and avic tilted back to normal position)...
I have a Clifford Alarm remote start ect ect.. is this something to do with the circuit and alarm not functioning together ok?.. or perhaps some wires not installed property.. what could cause this?
anyway.. thanks for your help in advance... the hum to the accelleration is the worst.. any ideas what to check?
PS: F-250 Platium, diesel, avic-z1, bluetooth, xm, ipod, clifford alarm w/remote start, custom sub box with 2 orion 10's, infinity ref 6x8 in the back, MBquartz component 5.5's and tweeters in front. 150x1 for the compnent punch amp, and 350x1 for the subs punch amp.. It thumps.. :twisted:
Posted Oct 06, 2006 · 20:07 UTC#2
Make sure you have a good ground in the car; if you don't I think that will cause the acceleration buzz.
Posted Oct 06, 2006 · 20:11 UTC#3
roger.. anything else i should check when i am in there?
Posted Oct 07, 2006 · 01:37 UTC#4
make sure the rcas coming out of the z1 aren't touching anything metal. that can cause the same problem. Do you have an amp on the interior speakers? Also if the z1 does what you're describing again, try stepping on the brake after you shut the truck off. It could have something to do with the remote starter backfeeding power into an accessory line or something.
Posted Oct 09, 2006 · 18:37 UTC#5
THanks.. i will check the rcas as well..
yes i have an amp to the int speakers.. i have 2 amps.. one to the component front speakers (avic powers rear)... and an amp for my subs..
i think that is good advice for the light problem.. i will try to brake if it happens again, but it hasn't all weekend...
i am gonna try to check this stuff this week sometime.. but i have been crazy busy the last few days..
I REALLY appreciate all your help guys.. i will post some pictures soon, i just want to finish everything first..
if any other ideas come up about things to check let me know..
Posted Oct 13, 2006 · 09:25 UTC#6
Did you work out the hummm? I have a F250 diesel and was told i need a power noise filter in-line of the power wire !
Posted Oct 13, 2006 · 19:37 UTC#7
ya.. i did get it figured out.
Car Tunes in San Antonio TX, got me fixed up. A Stud there named Josh, a friend of mine, took a look at it for me and figured it out.. he said that it was too close to the AV cables.. and moved the circuit WAY to the right of the unit..
problem solved.. no sounds..
