2008 toyota corolla wiring diagram
By jesusparedes · Feb 14, 2009in Vehicle Specific Wiring💬 2 posts👁️ 10,951 views
Posted Feb 14, 2009 · 14:54 UTC#1
I am trying to install a Code Alarm CA670 security and rem/start. could u help me out with the diagram, please? Thanks
Posted Feb 15, 2009 · 13:29 UTC#2
12 Volts white (25A) + ignition harness
Second 12 Volts black (15A) + ignition harness
Starter red + ignition harness
Second Starter N/A
Ignition black/white + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Third Accessory N/A
Keysense blue/black - ignition harness
Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Data Bus blue (RX), green (TX) data Immobilizer Module, 7 pin plug, pins 4 and 5
The Immobilizer Module is around the ignition key switch. The IMO wire is black at the ECM, second plug from left, pin 26. The IMI wire is white at the ECM, second plug from left, pin 27. The ECM (Engine Control Module) is behind the glove box. The security light wire is red/white (+) at the security light.
Can Bus High red data data link connector under driver dash, pin 6
Can Bus Low white data data link connector under driver dash, pin 14
Can Bus Sw N/A
Power Lock green - driver kick, 10 pin plug
Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue/yellow (double pulse) - driver kick, 10 pin plug
Meter these wires while turning the key in the driver door key cylinder. Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug.
Lock Motor blue 5 wire driver kick, blue 12 pin plug
Driver Unlock Motor red 5 wire driver kick, blue 12 pin plug
Parking Lights (-) green/white - headlight switch
Parking Lights (+) green + driver kick, harness to rear
Hazards yellow/black - flasher relay left of fuse box
Turn Signal (Left) green/black + flasher relay left of fuse box
Turn Signal (Right) green/yellow + flasher relay left of fuse box
Headlight red - headlight switch
AutoLights
Reverse Light red/black + front of fuse box, 10 pin plug
Left Front Door Trigger red - front of fuse box, 10 pin plug
Right Front Door Trigger same as left front door trigger
Left Rear Door Trigger same as left front door trigger
Right Rear Door Trigger same as left front door trigger
Dome Supervision same as left front door trigger
Trunk/Hatch Pin red/white - light in trunk
Rear Glass Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Trunk Release Motor N/A
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Trunk Alarm Shunt N/A
Tachometer black ac ECM, far left plug, pin 5
Wait to Start N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense purple/white ac ECM, second plug from left, pin 17
Brake Wire green/white + brake pedal switch
Parking Brake red/black - parking brake switch
Horn Trigger green/yellow - horn
