iGO sys.txt
By ill.die.trying · Feb 16, 2009in Hacks/Mods💬 22 posts👁️ 14,800 views
Posted Feb 16, 2009 · 00:54 UTC#1
found this online
[2d]
minguidancearrowsize=20
maxguidancearrowsize=65
minguidancearrowsize_zoomlevel=1200
maxguidancearrowsize_zoomlevel=0
guidancearrow_disappearlevel=600
guidancearrow_maxshift=12
[3d]
guidancearrow_first_size=1.1 ; scale of 1st arrow
guidancearrow_first_alpha=24 ; transp of 1st arrow
guidancearrow_second_size=0.8
guidancearrow_second_alpha=12
;guidancearrow_width ;
;guidancearrow_thickness ;
;guidancearrow_skew ;
;guidancearrow_zoomfactor ;
;guidancearrow_contour ;
;road_clip_plane_to_camera_height= ;
;road_clip_plane_camera_delta=50 ;
;3d_tmc_road_extra_width=200 ;
disable_3d_labels=0 ;
;use_all_building_textures=0 ; not?
;building_camera_distance_near=10
;building_camera_distance_medium=50
;building_camera_distance_far=500
fade_distance_for_car=50
fade_distance_for_guidance_arrow=500
;track_screen_ratio
;min_track_screen_ratio
;min_track_distance
;max_track_distance_lower
;max_track_distance_upper
;min_track_segments_shown
;max_track_segments_shown
;min_poly_distance
;max_poly_distance_lower
;max_poly_distance_upper
;min_poly_segments_shown
;max_poly_segments_shown
[3d_config]
roadsign_lines_per_screen=12
rotated_roadsigns=1
[bluetooth]
send_showphoneui_on_dial=1
[config]
SafeModeMinSpeed=40
autoset2donmap=1
autoset3doncockpit=1
hideroadaltname=1
overspeedrewarnbelow=1
[debug]
show_poi_boundingrects=1
show_poi_areas=1
show_performance=0 ; cpu / mem / whatever bars on top of screen
show_device_type=0
show_rawdisplay_info=0 ; handy for seeing what igo chooses as display driver
;max_memory=
;reserve_memory
run_on_mio_mantas=1
topmost=1
;nortc=1 ; dunno
buildneworderlist=1
poi_labels=1
sim_speed_factor_max=8.0
strap_waypoints=1
fov=40
tts_min_ready_wav=1
tts_getaway_time=200
tts_expected_engine_delay=1400
supress_straight=0
supress_highway_enter=0
supress_trivial_left=0
supress_trivial_right=0
;split_dual=0
;join_dual=0
;traincrossing=1
enable_buildings=1
enable_roadshadow=1
enable_roadsign=1
enable_landmark_occlusion=1
show_oneway_3d=1 ; 3d arrows in one way streets
show_oneway=1 ; show one way on or off
show_multinode_maneuvers=1
show_prohibited_maneuvers=0
show_priority_maneuvers=1
hide_itiner_crossing=1
show_gps_pos=1 ; this works again ;O)
show_signpost=1
replay_tmc=1
tmc_all_stations=1
show_pedestrian=1
pin_sets_start=1
compass_type=2
show_ltn=1
disable_3d=0 ;disables 3d buildings and roads
double_pixel_mode=2 ;3d mode fastdraw
doublepixel_stable_frame_time=500 ;time in ms before leavin fastdraw
skip_eula=1
show_arrows_on_route=1 ; little arrows in direction of route
show_lane_info=1
loop_sim=1
smart_2d=1
earth=1
show_plural=1
show_residentonly=0
autosave=1
speedcam_enabled=1
gnome_dem_files=1
show_turn_penalty=1
;disable_outlookpoi=1
[defaults]
mainroadness=60
shortessness=50
simplificationness=40
[device]
;type="MIOC210" ; force device type
;typeid=3
;In Igo8.exe: MIO device detected, use KernelIOControl method
[feature]
text_guidance=1
signpost_coloring=1
tmc_event_coloring=1
tmc_traffic_side=1
[folders]
app="%SDCARD%/iGO8" ; change this if applicable
;sdcardpath="\Storage Card"
;exe=""
;data="\Storage Card\igo" ;custom,save
;content="\Storage Card\igo\CONTENT"
;textures="custom"
;models="custom"
;secondary_root="IPAQ\NAV"
[gps]
background_navigation=1
logging=0 ; see also mydata.tracks
port=2
baud=38400
source="nmea"
disable_advanced=0
;default_latitude=48.857004
;default_longitude=2.294760
[interface]
;theme="skin\igo8_plus.zip"
skin="ui_igo8"
minzoomglobe=100000
show_gps_config=1
show_tmc_config=1
show_orientation=1
show_exit=1 ; obvious
disable_3dstick_labels=1 ;
mapfontscale=130 ; for 2d and 3d map
newalignment=1 ;
;default_poi_icon="Contacts" ;
show_zoombar=1 ; also see zoomscale_disappearing
show_timezoneslider=1 ;
;resolution_dir="320_240" ;
;maxzoom2d=60000 ; zoom out level (disabled get you into space ;O)
minzoom2D=40 ; zoom in level 2d
defaultzoom2d=1000
defaultzoom3d=500
defaulttilt3d=75000
autoscroll_on_click=1
;angleoffset=
;Zoom2dpercent=
popup_info=1
poi_show_all_btn=1
autotilt=0
;autotilt_minzoom3d=40
;autotilt_maxzoom3d=1000
;screen_snap_distance=40
exit_on_restart=0
use_spec_fav=1
spec_fav_count=4
empty_favorites=1
drive_carefully=0
[itiner]
show_only_ahead_of_car=1
[kml]
default_icon=1
[loading]
show_statustext=1
show_progressbar=0
progressbar_x=85
progressbar_y=134
;loading_bmp="loading.jpg"
;text_fontcolor=xFFFFFF
;text_fontsize=30
;text_x=100
;text_y=400
;text_w=600
;text_align: LEFT = 0,CENTER = 1,RIGHT = 2 JUSTIFY = 3
text_align=1
[local]
dateformat=6 ;
[map]
follow_gps=1
;3d_brunnel_shutdown=
alternative_roadnames=0
stop_rotate_on_map_move=1
;map_mode="3D"
;cross_border_routes=1
show_labels=1 ;
textured_poly=1
zoomscale_disappearing=1 ; works with show_zoombar
auto_nightmode=0 ; see also nightmode
show_oneway=1
inertia_on_map_move=1
shields=1
3d_landmarks=1
3d_buildings=1
3d_buildings_distance=2
3d_dem=1
3d_dem_detail=2
terrain_in_2d=0
3d_roads=1
3d_tunnels=1
3d_max_tiltlevel=7500
3d_max_zoomlevel=2000
3d_min_zoomlevel=40
3d_max_zfar=500
3d_scale_carmodel=1
3dcarsizemin=5000
3dcarsizemax=10000
3dcarsizemul=30000
minPolyDistances0 = 500
minPolyDistances1 = 500
minPolyDistances2 = 500
minPolyDistances3 = 500
maxPolyDistances0 = 2000
maxPolyDistances1 = 3000
maxPolyDistances2 = 4000
maxPolyDistances3 = 5000
minTrackDistances0 = 500
minTrackDistances1 = 500
minTrackDistances2 = 500
minTrackDistances3 = 500
maxTrackDistances0 = 2500
maxTrackDistances1 = 3500
maxTrackDistances2 = 4500
maxTrackDistances3 = 5500
maxFovRatioForPoly=8
roadblockicon_maxzoom=2000
[msnd]
; How does msdn work? Movies, Weather, Petrol prices, etc.....
msnd.start=0
[mydata]
max_favorites=16
;num_favicons=7
;favicon=""
max_histories=40
[mydata.tracks]
auto_track_visible=1
record_auto_track=0
;tracklog_folder=""
[navigation]
skip_grab_viewchanging=1
sim_speed_factor=1.0
show_current_city=1
show_countrychange=1
autoreplan_action="AUTO"
gps_pos_to_road=1
[other]
demo_mode=1
[phone]
;driver="TAPI"
;exe_path="\Windows\cprog.exe"
;win_name="Phone"
[poi]
enable_pois_before_080217=1 ;080217 is the date can be changed as needed
multipoi=1 ;allows you to use more than one set of POIs at a time (will show duplicates though)
[power]
;backlight_sync_with_OS=1
;powermgm_state=0
backlight_day=100
backlight_night=54
;power_off_mode=1
;power_off_timeout=300
battery_warning_limit=10
;backlight_slow_api=1
[rawdisplay]
highres=0
;driver=GX ;GDI or GX
;class="landscape"
; or rlandscape, portrait, square,wide
screen_x=320
screen_y=240
stretch=0
[route]
correctness=80 ; we used to have a slider for that
allow_unpaved=0
allow_highway=1
allow_ferry=1
allow_charge=1
allow_uturn=1
allow_special=0
allow_carpool=0
route_type="ECO"
planned_route_weight=7
scenic_highway_weight=4
scenic_scenic_weight=2
tmc_weight=6
;vehicle_type="truck"
;slow_car_speed
;slow_car_multiplactor
;fast_car_speed
;fast_car_multiplactor
;motorcycle_speed
;motorcycle_multiplactor
[screen]
nightmode=0
menu_animation=0
;focus=1
;focus_type=2
;focus_color
;focus_sprite
;focus_halign
;focus_valign
;focus_followlinks
;focus_list_move_before_scroll
;focus_list_keyup
;focus_list_keydown
;focus_list_keyleft
;focus_list_keyright
;focus_activator_key
;current_background="default.bmp"
[settings]
accident_recalc=0
accident_map=1
accident_panel=1
closed_recalc=0
closed_map=1
closed_panel=1
heavy_recalc=0
heavy_map=1
heavy_panel=1
congestion_recalc=0
congestion_map=1
congestion_panel=1
roadworks_recalc=0
roadworks_map=1
roadworks_panel=1
closures_recalc=0
closures_map=1
closures_panel=1
danger_recalc=0
danger_map=1
danger_panel=1
weather_recalc=0
weather_map=1
weather_panel=1
police_recalc=0
police_map=1
police_panel=1
invalid_recalc=0
invalid_map=1
invalid_panel=1
[smartzoom]
restore_smartzoom_on=1
enabled=1
enabled2d=1
;use2d is to use separate smartzoom for 2d and 3d. Once this is implemented in a UI it should be set to 1.
use2d=1
minzoom=60
maxzoom=250
auto_follow_on=1
autozoom_coord=200
autozoom_address=100
autozoom_cos=200
auto_follow_time=10
auto_smartzoom_time=8
zoom_after_find=1
default_visibility_altitude=4000
overview=0
overview_zoomlevel=10000
overview_distance=20000
minangle=8
maxangle=85
[speedcam]
usemio=-12,90,37,27
disable="_SUI", "_GER", "_AUT"
;speedcam_sound="!alert1"
enable_at_startup=1
[sound]
queue_length=200
ding=0
sound_volume=255
voice_volume=255
sound_muted=0
voice_muted=0
;device_samplerate=
;device_bps=
;device_stereo=
;suspend_time=5 ;timeout for wavedev to goto sleep
;use_os_volume=1
dynamic_volume_type=1
dynamic_volume_minspeed=40
dynamic_volume_maxspeed=100
dynamic_volume_voicemaxspeed=80
dynamic_volume_voice_volume_max=100
dynamic_volume_os_volume_max=255
;incomingcallsetting=0
[timezone]
default_timezone=29 ; GMT+1 amsterdam
index=29
auto_index=29
sync_time=1
reset_os_timezone=0
sync_os_timezone=0
use_auto=1
manual_dst=0
[tmc]
port="COM,1"
baud=38400
source="gns"
;harman eten galik opentmc2 opentmc1 hyundai samsung amaryllo royaltek gns
auto_detour_calc=0
;announce_total_route=1
ignore_all_events=0
[tripcomputer]
num_of_trips=4 ; default igo8 has only 3
[tts]
tts_buffer=131072
announce_exit_directions=1
tts_logics=3
priority="HIGH"
always_say_road_names=1
announce_street_name=1
skip_exit_numbers=0
[usb]
enable_on_shutdown=1
disable_on_startup=0
quitmap_msg_quits=0
[warning]
speedwarn_alt_builtup_based=1
pedestrian_warning=0
speedcam_visualtype=1
speedcam_soundtype=1
speedcam_warning=1
speedlimit_warning_voice=1
speedlimit_warning_visual=1
speedwarn_tolerance=110
speedlimit_warning=1
;pedestrian_warning_threshold=
;speedwarn_toltype
;speedwarn_alt_toltype
;speedwarn_alt_limit
;speedwarn_alt_builtup_based
;speedwarn_alt_tolerance
approach_beep_distances=200
warn_distances=100
section_beep_distance=200
;speedcam_max_angle=20
speedcam_snap_distance=200
speedcam_max_lookahead=400
speedcam_maxdistance_from_road=10
overspeed_sound= "!alert3" ; speedcam sound
;max_section_time=240
section_beep_sound= "!sectionbeepA"
approach_beep_sound="!sectionbeepB"
section_start_sound="!sectionstartA"
section_end_sound= "!sectionend"
Posted Feb 16, 2009 · 11:33 UTC#2
now this looks helpful and awesome. but what does this mean? 2d map north up?
thanks for the search =)
Posted Feb 16, 2009 · 11:40 UTC#3
Hopefully that it puts North facing up in 2D.
Any confirm on this?
Also the last bit should indicate there is span set for the alarm on the speedcam.
Posted Feb 16, 2009 · 13:09 UTC#4
Which version of iGo did this come from? I believe in the latest (8.3?) 2D North up has been fixed.
Posted Feb 16, 2009 · 16:07 UTC#5
this is for 8.0
Posted Feb 16, 2009 · 17:49 UTC#6
Have you tried it yet? If I remember to try after work I will and see what happens 8)
Posted Feb 16, 2009 · 18:20 UTC#7
Many of those settings won't apply to the F-Series, but it's still worth trying (I can't remember if anyone has tested it before).
Let us know what you find.
Posted Feb 16, 2009 · 18:24 UTC#8
Some were tested (i.e. 3D arrow sizxe control, original speedcamera hack... all in SYS.TXT). Some only apply to smartphones, but the rest could be useful.
Posted Feb 16, 2009 · 18:29 UTC#9
So really we need someone to take the time to go through line-by-line and apply comments to each setting regarding the functionality and whether or not it applies to the F-Series.
Maybe we can all just start biting off small pieces as we make other mods, and post them to this thread? I'll compile a complete list if we get enough useful information.
Posted Feb 16, 2009 · 18:32 UTC#10
i'll start,
[navigation]
show_current_city=1
gps_pos_to_road=1 ; snap to road option, on/off selection is on route setting
for this to work add the highlited one on your setting_800_480.ui
; Route ***********************
Posted Feb 17, 2009 · 00:27 UTC#11
[mydata]
max_favorites=16
;num_favicons=7
;favicon=""
max_histories=40 ;works. Our units appeared to be set at 32 stock.
[navigation]
show_current_city=1
autoreplan_action="AUTO" ;not sure if it works 100% of the time but the unit has not said off-route and not re-calculate since I put it on about 2 weeks ago.
gps_pos_to_road=1
3d_min_zoomlevel=40
3d_max_zfar=500
3d_scale_carmodel=1
3dcarsizemin=5000
3dcarsizemax=10000
3dcarsizemul=30000 ;all work as has been discussed in many other threads. You'll need to play with values to get the view and car size that's suitable for you.
Posted Mar 01, 2009 · 14:54 UTC#12
Even with the edit above, the (new) radio button is disabled if vehicle type is "Car" (F90BT). This is disabled in common/ui/setting.ui and then defaulted to off in other cases. Comment out the following (note the comma in the first edit):
;-----my init
ui_SettingRoute.y 0
runif nVehicle 0 'nVehicleTmp.set "Car", btn_vehicle_value.set "Car"'
else_runif nVehicle 5 'nVehicleTmp.set "Pedestrian", btn_vehicle_value.set "Pedestrian"
;, btnSR_AlignToRoad.DISABLE'
runif nVehicle 5 'rdkeepposon.enable, rdkeepposoff.enable'
else_runif nVehicle 6 'rdkeepposon.enable, rdkeepposoff.enable'
;else_run 'rdkeepposon.disable, rdkeepposoff.disable'
With these two edits, there is no need for the hard coded gps_pos_to_road=0 in sys.txt!
Posted Mar 02, 2009 · 10:08 UTC#13
is there a line for the sys.txt which takes care of that tiny black dot (the actual GPS position) which is under, over and besides my arrow icon?
It annoys me :?
Posted Mar 02, 2009 · 10:26 UTC#14
It annoys me :?
Maybe this:
[navigation]
gps_pos_to_road=1 ???
Change to:
[navigation]
gps_pos_to_road=0 ???
Posted Mar 04, 2009 · 23:48 UTC#15
[mydata]
max_favorites=16
Works. I set this to 60 before my trip. Just checked all 60spots are filled.
Posted Mar 05, 2009 · 01:35 UTC#16
It annoys me :?
[debug]
show_gps_pos=1; 1 - Show, 0 - Hide
Although it is a useful function...
Posted Mar 07, 2009 · 14:03 UTC#17
It annoys me :?
[debug]
No, that's not it.
and how is it useful?
Posted Mar 07, 2009 · 18:14 UTC#18
its nice when you are not on a road so you know where you are
i wish i could make it bigger
Posted Mar 07, 2009 · 19:50 UTC#19
what are you doing off road :P
Posted Mar 07, 2009 · 20:12 UTC#20
anything i can do off road i spend alot of my time up in the mountains
my main reason for buying this unit was because i got tired of cds skipping on ruff roads or no roads
Posted Mar 08, 2009 · 06:57 UTC#21
It annoys me :?
[debug]
No, that's not it.
It also tells you a) how are maps different from real life and B) how far off your GPS reception is...
Posted Jun 07, 2009 · 15:30 UTC#22
[tripcomputer]
This one works. I set it to 6 and they're all functional independantly
