snap to road
By ill.die.trying · Feb 16, 2009in Hacks/Mods💬 10 posts👁️ 1,526 views
Posted Feb 16, 2009 · 01:27 UTC#1
[navigation]
skip_grab_viewchanging=1
sim_speed_factor=1.0
show_current_city=1
show_countrychange=1
autoreplan_action="AUTO"
gps_pos_to_road=1
is that a snap to road option?
Posted Feb 16, 2009 · 03:22 UTC#2
just tried it and it works,
Posted Feb 16, 2009 · 03:38 UTC#3
What exactly does this do?
Posted Feb 16, 2009 · 03:46 UTC#4
the arrow doesn't snap to the road, like the one Borism did, i just don't know if it'll have the on off option like the ones Borism have,
Posted Feb 16, 2009 · 06:14 UTC#5
If you just hardwire it in SYS.TXT than it will always be on (or off). If you want to be able to toggle it you need a settings screen for that....
Posted Feb 16, 2009 · 17:41 UTC#6
just found out that the setting is already there, i went to look at the route setting and it has the option for you to be able to turn it on/off
Posted Feb 16, 2009 · 18:16 UTC#7
500 has it (since it can be used in pedestrian mode). For 700-900-90 it takes a hack.
Posted Feb 16, 2009 · 19:43 UTC#8
now i figured it out, i used your hacked setting file for the speed cam,
Posted Feb 16, 2009 · 21:22 UTC#9
Thought I'd help out by posting the following regarding 'Snap to Road'. I had no idea what the phrase meant so I Googled it and found the following, it may help others understand a little better if they wish to install the hack.
Snap to Road (a.k.a. as Lock to Road)
This is a feature used by all high-end navigation systems to ensure that your position is shown on a road and not a few millimeters next to it, something that most people would consider distracting. The downside to this is that when reception is bad, your GPS position can be too erroneous to enable the program to interpret it correctly and as a result it might get confused and "snap" you to the wrong road and re-route you. I've seen this happen with Destinator (in NMEA mode) but also with Garmin's GPS V standalone unit.
Still this is a feature that's desirable. AFAIK only two programs currently do not implement it, Teletype and Mapopolis
Regards
Pete
Posted Feb 17, 2009 · 00:02 UTC#10
I have the 500 so the ability to unsnap came stock. From what I understand snap to road only is standard in the rest of the models. I can tell you first hand that when it's not snapped and you stop, the display goes in circle trying to figure out which direction you're facing.
