INSTALL HELP ON N2
By cavikid · Oct 07, 2006in Problems/Troubleshooting💬 10 posts👁️ 1,743 views
Posted Oct 07, 2006 · 13:09 UTC#1
HEY I just bought a avic n2 and i was having a problem finding my vehicals vss i have a 03 cavalier and i was also having a problem to set the gps to my location please help thanks alott
Posted Oct 07, 2006 · 13:54 UTC#2
VSS Wire: LOCATION 12- ECM- BLUE CONNECTOR POSITION 34
VSS Wire Color: GREEN/WHITE
Posted Oct 07, 2006 · 14:07 UTC#3
i just called cruchfield and they said it was on the passinger side strut tower and it was pin J 7 let me know thanks
Posted Oct 07, 2006 · 14:26 UTC#5
how do u tell if the vss is hooked up
Posted Oct 07, 2006 · 14:34 UTC#6
Iff you check under the connection status screen, the one that says speed pulse will go up and down depending on how fast your car is going.
Posted Oct 07, 2006 · 14:34 UTC#7
Posted Oct 07, 2006 · 14:43 UTC#8
cntrylvr79 which is the vss is it the green and white on driver side J 7 OR IS it the other one he said
Posted Oct 07, 2006 · 15:24 UTC#9
Could be both. The one I quoted you was for the cruise control system. The VSS lead goes into there. I don't know what crutchfield was mentioning, but that might be your PCM module, which would also have a VSS lead in it.
Posted May 21, 2007 · 18:36 UTC#10
www.v6z24.com
