Why is it that when I produce my own BMP files, the AVIC refuses them to load and displays an error, stating it cannot load the bitmap?
Are they 32 bit?
24?
what?
Are they 32 bit?
24?
what?
PAq,
Are you saving them as Windows format??? if you save as os2 format they won't load..
GUGA
That... I don't know ![]()
I made some with Paint.Net.
No mather of I save them as 8 or 24 bit, they don't load.
Can I use PNG instead?
(or any other format _but_ BMP?)
24-bit in Photoshop.
alternative software (don't have PS)
And 24-bit from Paint NET doesn't load (at least not with transparancy)
Try getting a free program called IRFANVIEW.
It is the best picture viewer for the PC and has a lot of conversion utilities built in.
You could try converting your pictures with it to see if they load.
You need MioMap tool, iPaq Image Explorer, IgoConvert or one of the other programs that can compress/decompress iGO's custom bitmap format...
Paq,
What images are you trying to change? the unit images or the igo images?
GUGA
fyi only 16bit color can be displayed on lcd's regardless of settings
Trying to change bmp images for the navigate map in the ui
