Ok I'm tired of searching "GPS/XM antenna placement&quo
By zukgod1 · Feb 16, 2009in General💬 17 posts👁️ 1,831 views
Posted Feb 16, 2009 · 18:23 UTC#1
Ok yes I searched for quite a while but i was unable to locate an answer.
What I want to know is where everyone is placing their antenna's.
I just removed my Z1 from my jetta and I had both the antenna's placed in the dash on each side under a speaker cover. I had made a metal plate to go where the speaker goes and I placed the GPS and a tweeter in each.
Now I'm going to install this into an 02 Passat and there are no dash speaker covers.
I would rather not put them on the outer surface of the dash that would just be unsightly.
I've heard of people mounting them under the dash (inside) on a cross bar etc and have no problems with reception. I would like to do this but in the case that's not best I would like to know before hand.
Anyone have some input for me?
Thanks for your help.
Posted Feb 16, 2009 · 20:33 UTC#2
It is trial and error for each car. Try it and check signal strength. I have my GPS under the dash in my Dodge Truck, and I use the factory XM antenna.
Posted Feb 16, 2009 · 21:08 UTC#3
Thank you sir will do.
I was thinking of putting them in the back window but I would rather not run them all the way back there if possible.
Also I don't time to do the full install right now so I was going to start running things like the GPS antenna's. and getting the XM tuner placed.
I'm waiting for the Pioneer cage to show up so I can mount the dang thing.
Posted Feb 16, 2009 · 21:13 UTC#4
Hey does anyone know the dims on the metal shield that comes with the antenna's
Posted Feb 17, 2009 · 00:45 UTC#5
What 'dims'?
Posted Feb 17, 2009 · 00:53 UTC#6
the measurements of the metal plate the gps ant sits on. Black and looks to be either 3 or 4" sq
Posted Feb 17, 2009 · 01:27 UTC#7
Yes, I know the metal plate, but not sure exactly what you are asking...
The GPS antenna MUST be mounted to something metal. If you attach the antenna to metal, you don't need it. If you attach the antenna to a plastic dash, or on top of a plastic heater vent, etc, then you need to use the metal plate. The metal plate actually strengthens the GPS signal.
Posted Feb 17, 2009 · 01:30 UTC#8
the dimensions are like 3-3.5 square inches.
Posted Feb 17, 2009 · 01:43 UTC#9
I needed to know so if i decide to put them in the back window i'll need to make a couple.
Posted Feb 17, 2009 · 01:45 UTC#10
You only need one for the GPS antenna.
Posted Feb 17, 2009 · 01:47 UTC#11
What about XM?
Posted Feb 17, 2009 · 01:50 UTC#12
It does not have to have a metal base. You can double side tape it if you want...
Posted Feb 17, 2009 · 01:53 UTC#13
Awesome! thank very much :)
Posted Feb 17, 2009 · 05:41 UTC#14
Just putting it out there... That the GPS antenna does not seem to truly NEED the metal mounting surface...
I have mine just sitting(with intentions to fab up a metal plate) under my dash ATM... And it's accurate on the map... That's not to say that the signal strength couldn't be better...but it works just fine for my needs...
Just throwing it out there... like Garrett mentioned, you may want to exsperiment..
Posted Feb 19, 2009 · 21:41 UTC#15
I have both of mine (xm and gps) sitting on the dash with double sided tape over in the corner on the passenger side right by the A pillar...looks tacky but works great. I wanted to hook my xm up to the factory sirius antenna but everyone told me I could not do it so I just used the one that came with the xm adapter kit.
Posted Feb 19, 2009 · 22:02 UTC#16
Thanks all for your replies.
I received my mounting kit today so I'm going to start running wires tonight then finish up Saturday.
If all goes well I'll be listening to my XM through the Z on the way to work Monday.
Posted Feb 20, 2009 · 02:43 UTC#17
So haw many satellite "bars" do you guys usually get? Mine usually shows 4-6, averaging 5.
The antenna is sitting on top of the frame, picking up the signal through the plastic body. Mapping seems OK but not as accurate as the N2 it replaced wih the same antenna location.
