Completely returning the navigation system to the initial state
To return the entire navigation system to the default or factory settings, initialize the navigation system in the following order:
1 Press RESET button on the hardware.
2 Initialize the user data area on the hard disk drive.
3 Clear the learned data in the sensor.
Steps to follow:
1 Turn the ignition switch off.
2 Press RESET button and hold.
3 Start the engine. After a few moments, the start-up screen comes on for a few seconds. Release the RESET button.
4 Touch and hold MAP button while the start-up screen is displayed. “Clear memory screen†appears.
5 Touch [Clear user information from hard disk]. *This reset operation clears all music data recorded in the music library. Note that the cleared data cannot be restored.
6 Touch [Yes].
The user area in the hard disk drive is initialized.
After that, the navigation system restarts.
7 Press MENU button and then touch [settings].
The setting menu appears.
8 Touch [Hardware] and then touch [3D Calibration Status].
9 Touch [Learning Status] and then touch [Reset All].
