Problems with Pioneer iPod plug
By erilude · Feb 16, 2009in General💬 19 posts👁️ 2,936 views
Posted Feb 16, 2009 · 22:13 UTC#1
I have the f900bt and I have the pioneer spade to usb/rca connection. My problem is every time I get in my car and my 80gb 5thgen iPod is in the glove box, it doesn't recognize it. So I have to unplug it and plug it back in then it takes like 7 minutes to update and access all of my music. It also doesn't start on the last song played and resets it to the first song on my iPod!
Help Plz, is this a programing issue??
Posted Feb 16, 2009 · 22:57 UTC#2
Is your radio updated to firmware 2.0?
Posted Feb 16, 2009 · 23:27 UTC#3
the usb connector is a common problem with this unit. try swaping out the cable and make sure your ipod has the latest update. seen this problem several time and pioneer is re-enginnering the cable to fix it. it a common problem.
Posted Feb 16, 2009 · 23:29 UTC#4
If you do replace the cable, use Apple's Composite A/V cable kit. It's much higher quality than the POS that Pioneer supplies, and it is the same price.
Posted Feb 16, 2009 · 23:49 UTC#5
also the apple cable will also allow for video out of an iphone or ipod touch.
Posted Feb 17, 2009 · 00:13 UTC#6
So does the Pioneer.
Posted Feb 17, 2009 · 16:58 UTC#7
Isn't the USB cable perm attached to the HU? Also, you say the f90bt will play video from the touch/iphone? Mine will not. the video button is grayed out. I am assuming it is due to the cable? If I buy the apple cable, will it recognize video then?
Thanks,
Brian
Posted Feb 17, 2009 · 17:02 UTC#8
Yes, the female USB connection is permanently attached, but the Pioneer or Apple Composite cable will plug into that.
Do you have the Touch or iPhone, and which version of the software are you using?
Posted Feb 17, 2009 · 19:06 UTC#9
I am using a touch, my f90bt has the 2.0 update.
Brian
Posted Feb 17, 2009 · 19:46 UTC#10
I had the same problem out of the box...but you just have to go into video settings and change the input of av1 to ipod, it'll work, guaranteed!
Posted Feb 17, 2009 · 20:44 UTC#11
under av settings, I have the first one connected to Ipod.
Posted Feb 17, 2009 · 23:07 UTC#12
What firmware is your Touch running? IIRC, one of the updates Apple issued killed video playback from the Touch.
Try doing a search, I thought that issued got resolved, but I don't know for sure.
Posted Feb 18, 2009 · 00:21 UTC#13
as far as i know from talks with apple, there is and excuse the spelling, an authincation chip in the actual apple cable. i tried a pac ic-av2 on my home tv to get video out and didnt work. used the appl cable with my 32g touch and got a video signal. im tellin you it something in the cable. if all else fails apple is great on returns so if it dosent work you have nothing to really loose excep some time. i will test it on a 90bt when i do an install later today.
Posted Feb 22, 2009 · 22:31 UTC#14
I bought an apple cable Friday, installed it, still no video. Pulled it out and took it back for my 40 dollars back. Still no video with my touch.. :/
Brian
Posted Feb 22, 2009 · 22:37 UTC#15
I have the problem of the Ipod not being recognized as well. I think it may be a problem with the female USB connection. Lately I've been able to "refresh" the connection by just replugging in the USB connection (not the Ipod connection). I thought this might be a problem with the A\V cable until last night when I was trying to use my USB thumb drive. When I rebooted the unit, the drive was not recognized; just like the Ipod. I replugged it in and it worked.
Posted Feb 22, 2009 · 23:04 UTC#16
Brian
Have you updated your iPod to the latest software ? I had the same problem until I updated my iPod, then the video worked fine.
Posted Feb 22, 2009 · 23:38 UTC#17
I just checked. only update available is 2.2.1 which is the pay one for apps. I don't think my v 1.5.something is the problem :/
Brian
Posted Feb 23, 2009 · 00:59 UTC#18
Yep, that's your problem, trust me and try it.
Posted Feb 23, 2009 · 14:10 UTC#19
Hey man, I updated my ipod with the 10 dollar 2.2.1 update and the video now works with the Pioneed cable! Thanks a bunch. I was skeptical, but it worked. Kinda grainy resolution since the touch is so much smaller, but still decent. Thanks!!! And I apologize for doubting you :)
Brian
