Hey my bluetooth connects when i get in my car then but then it will disconnect and repeat this over and over again any ideas of what would cause this?
Bluetooth keeps disconnecting
First of all, this is a troubleshooting question, and as such should be posted in that forum.
Next, we need to know what device you have paired if we have any chance of helping you. Have you tried pairing another device? If so, what happened? If not, do that first.
I experienced a similar problem when I decided to turn of the Bluetooth notification LED on my Blackberry. My AVIC-F90BT would connect and disconnect from the phone every few minutes.
I turned the notification LED back on and the problem went away.
What brand and model is your phone? I didn't have any problems with my previous Nokia 6110N phone with S60 operating system. But when I got my new phone, still a Nokia S60 phone which is 5800 Xm, it kept disconnecting. After some fiddling I discovered that in Bluetooth settings on the phone switching off the "Remote SIM Mode" solved my problem.
I had what sounds like a very similar issue with my Samsung Flipshot. Finally, took it back to Verizon and got a new one, it now work fine, the guy said that it had something to do with the "early" Flipshots, we got the forst one last April.
