ipod not working!!!
By lsutyger03 · Oct 07, 2006in Problems/Troubleshooting💬 12 posts👁️ 2,082 views
Posted Oct 07, 2006 · 18:10 UTC#1
I hooked every thing up and I don't see the ipod option on the screen. Did I miss something.
Posted Oct 07, 2006 · 18:20 UTC#2
Do you see EXT as one of the sources? When you plug in the ipod does it say Pioneer on the screen of the ipod?
Posted Oct 07, 2006 · 20:33 UTC#3
Its does say anything on the ipod just the song . The ext buttons dimmed meaning I can't push them.
Posted Oct 07, 2006 · 23:47 UTC#4
Are you using the pioneer ipod adapter? If you are, check the fuse in the yellow wire. Make sure the black wire is grounded. Also make sure the ipbus cable is plugged into the black port on the interface. May seem dumb, but also make sure the cable is making solid contact to the dock connector of the ipod.
Posted Oct 08, 2006 · 00:05 UTC#5
I ve checked all of those things. the guy a cc said that I need to update my ipod. Is this possible?
Posted Oct 08, 2006 · 00:09 UTC#6
That is a possibility which gen is it?
Posted Oct 08, 2006 · 01:20 UTC#7
Im not sure it a 30gb ipod video
Posted Oct 08, 2006 · 02:48 UTC#8
well I updated it and it still doesn't work.
Posted Oct 08, 2006 · 05:41 UTC#9
YOur pod should work with that the, I'd say either something is not connected properly or something is wrong with the ipod interface.
Posted Oct 08, 2006 · 08:37 UTC#10
My 30gig ipod worked without updating. Take it back to your circuit city guy and tell him he installed it wrong.
Posted Oct 09, 2006 · 02:17 UTC#11
Well i talked to a tech from crutchfield and he walk me through some things but finally decided it was defective. So I will be getting another one this week.
Posted Oct 27, 2006 · 19:32 UTC#12
i had the same problem with the ipod interface, it worked in the begining anf then it stopped!! Im taking it back. Im gonna connect a tv tuner with DVD/MP3 player and a MP3 cd changer and will just use that for now.
