Problems with F90-bt already.. please help
By VeNoM0713 · Feb 16, 2009in Problems/Troubleshooting💬 8 posts👁️ 1,317 views
Posted Feb 16, 2009 · 23:39 UTC#1
well for some reason, my gps signal gets lost basically everytime i turn the car on. so today i tried going into testmode and deleting my flash disk files and reupdating to ver 2.0 but it still will not get a gps signal..it worked for a little bit but when it dd work, i had all yellow bar strength on like 6 sats.. this just recently started happening right out of the blue.. i have my antenna on the rear deck in my car so its right in the field of view of the sky.. am i going to have to get this replaced? and also, it started giving me the message saying my parking brake isnt properly connected but it really is and i did the software bypass.. it was working this whole time but for some reason, now it wants to start giving me problems.. any help would be appreciated.
Posted Feb 17, 2009 · 00:02 UTC#2
mount your gps antenna on a metal pad that came with the unit
when you deleted your files you deleted your bypass.. do it again
Posted Feb 17, 2009 · 00:09 UTC#3
i did.. like i said before, i never had a problem with my unit getting a good gps signal and also, i did re-do the software part of the bypass and it still shows me that message.. is my unit defective somehow or should i try to delete my whole flash disk and copy my old one?
Posted Feb 17, 2009 · 00:13 UTC#4
not sure.. if you have poor gps try moving the antenna even outside to the roof as a test..
you did not do the bypass right.. im sure of it.. try the hardware bypass and check to make sure your gps antenna is properly connected and seated right..
Posted Feb 17, 2009 · 00:21 UTC#5
lol i swear to god i did the bypass right.. it just started showing me that warning screen and it only does it once in awhile.. its weird. but about the gps reception.. why wouldnt it work now when it was working perfectly before? i dont get that..
Posted Feb 17, 2009 · 00:35 UTC#6
what value did you set for the software bypass? you could be exceeding the speed you set. if it does it in park or low speeds you did it wrong
Posted Feb 17, 2009 · 03:22 UTC#7
Check the cable on the GPS antenna, you may have pinched it somewhere or it may even be loose at the HU.
Posted Feb 17, 2009 · 22:02 UTC#8
thanks for the replies.. im going to check everything out again to make sure it all looks good.. it seems as the gps works when it wants to.. it worked for a little bit yesterday and not at all today.. i honestly dont know whats going on with it
