hi,
How is the GPS reception and battery performance of F500BT
hi,
GPS reception good. Battery life bad
Ditto.
But substitute 'really crap' for 'bad' ![]()
i think the battery problem is general problem of GPS devices.
Lets talk about GPS reception. What is general cold start time? Generally it will take 30 seconds. What about f500bt?
I get a whole day between recharges ![]()
how? without using whole day ![]()
Must have a short commute ![]()
The battery problem is even more of a problem when you have a 5.8" WVGA screen instead of a 3" shitty one like most portable navs
I can get a whole day too............ get up in morning, disconnect charger, turn 500 off, go to work, arrive home, turn 500 on, reconnect charger - brilliant ![]()
Seriously tho, the massive screen does take a lot of power, but surely it should have been equipped with a larger battery
battery of f500bt is replaceable?
i heard somewhere if you discharge and charge battery 5 times it will be as its first day. After that it will last long as first day.
And please say me when i get in the car how will it take to begin navigation generally? will i be have any problem about GPS reception?
My battery was shite from day one, so, yeah, same as first day.........
Not a prob as I use it only in my car, and thats got a much bigger battery
