Ok, I have searched and this is the best answer I found (see info from dgurjala below my manuscript) however not being very tech savvy, someone please clarify a few things for me (unless someone can link a step by step thread the explains it for dummies like me):
1. After I download and decompress the data.zip file on my PC do I put on the SD card in the root menu? Or do I need to create a directory in my SD specifically? I already have the two files on the SD card to boot into test more, do I just put the Data.zip next to them?
2. Assuming that question #1 is answers as is, after I boot up the F500 in test mode, open up my flash folder and find this data.zip file, where do I extract it into the windows CE in order for it to stay in the system, or do I just leave it on the card?
This might seem a very amateur question but I am as green as it gets on this topic. Thanks in advance
dgurjala wrote:
just to clarify guys, so I uncompress the data.rar file, then place the data.zip file in the usual My Flash Disk/APL2/iGo/ directory, right?
What do I do with the sys.txt, finalnew.ttf, finalold.ttf, and tahoma1.ttf files?
thanks in advance...
Those also go into My Flash Disk/APL2/iGo/, next to DATA.ZIP.
