KenwoodDNX5120 iphone(sorry this is the best forum for this)
By SuperMiguel · Feb 18, 2009in General💬 5 posts👁️ 1,033 views
Posted Feb 18, 2009 · 18:16 UTC#1
is there any benefits on using my iphone with a Kenwood KCA-iP300V cable compared with using a standar 3.5mm cable connected directly to the ipod audio port on the back of the HU???? thanks
Posted Feb 18, 2009 · 19:44 UTC#2
This sure isn't the right forum, but I'll take a crack (note: this is from my bad memory of my Kenwood install 3 years ago).
iPod Cable
Pros:
Will let you control the iPhone from your stereo.
Will charge the iPhone.
Will usually sound better than the phono jack
Cons:
More expensive.
Will not allow you to receive calls (not sure on this so check it).
Will not allow you to control the device locally (this may have been addressed).
Regular 3.5 cable
Pros:
You can control the iPhone locally
You can receive calls
You can adjust volume via the iPhone
Cheaper
Cons:
Does not charge
Can intruduce static
Check out reviews on Crutchfield or Amazon and usually people will tell you what it can and cannot do.
Good luck!
Posted Feb 18, 2009 · 20:25 UTC#3
is the audio difference really big?? like can i notice the difference?
Posted Feb 19, 2009 · 00:23 UTC#4
The bummer about the iPod/iPhone is that there is no true digital out. Even the doc puts out an analog signal from what I have found which is a result of copy right agreements
That said, there is not a huge difference at all but sometimes you can get a crackle when adjusting the volume as deposits build up on the connections.
My advice would be to go to radio shack and spend $3 on a phono cable and try it out. Worst case you return it or eat the $3 . :)
Posted Feb 19, 2009 · 03:07 UTC#5
Or get an ebay ipod cable and have the best of both worlds. its 7 bucks and i love mine
