IC board diagram
By Wolfz23 · Feb 19, 2009in Problems/Troubleshooting💬 2 posts👁️ 619 views
Posted Feb 19, 2009 · 04:00 UTC#1
My Z1 has an internal issue. When I remove switched power from the unit, the unit doesnt turn off. I physcially disconnected 12v switched (red) from any conneciton, and the unit stays on.
Its clearly an internal isses most likely a bad Diode, but im not sure where.
anyone have a diagram of the power circuit internally?
thanks
Wolfz23
Posted Feb 19, 2009 · 20:25 UTC#2
I'm sure it's in the service manual...
Have you tried a different wire harness or checked to make sure yellow and read aren't reversed(I'm sure you have, but just in case)?
