coding help to make stock clock show house numbers
By blackh8552 · Feb 20, 2009in Hacks/Mods💬 4 posts👁️ 735 views
Posted Feb 20, 2009 · 02:36 UTC#1
Well I feel like a noob today considering I do computer programming for a living.
I want to implement this hack that maverickster showed but i dont want the change in clock or size. I want to use the stock clock and press it to show house numbers or the compass button doesnt matter which one. Any suggestions on how to modify this code? :?:
CLOCK/HOUSE NUMBER MOD
Step 1 - Find the ";time" code in the navigatemap_800_480.ui file in the DATA/ui_pioneer/800_480/ui folder in the DATA.zip file. Replace it with the following and edit the font size, font color, and alignment to taste:
Code:
;Clock
Step 2 - Find the first occurrence of "" in the navigatemap_800_480.ui file in the DATA/ui_pioneer/800_480/ui folder in the DATA.zip file. Then add the following code beginning on the next line after the first "":
Code:
;house numbers display
Step 3 - Add the bmps in the attached zip file to the DATA/ui_pioneer/800_480/ folder in the DATA.zip fle.
RESULTS: This will make the clock bigger (although you can adjust the font size in the code yourself) and will make it clickable. If you click the clock, it will display the house numbers adjacent to your current location immediately below the current gps location arrow. Press the house numbers to clear them.
Posted Feb 20, 2009 · 02:41 UTC#2
In the clock part, just add the onrelease code, don't change font/size settings of the clock. Add the house numbers layer as posted.
Posted Feb 20, 2009 · 02:49 UTC#3
so thats it? thats all i have to add? plus the layer code obviously
;Clock
Posted Feb 20, 2009 · 03:05 UTC#4
;Clock
Not quite. Find the clock element in the navigatemap_800_480.ui:
Leave font, color, etc. attributes as they are, but add onrelease action before the closing bracket.
Alternatively, use my housenumbers mod -- it puts them on the current street line, left and right of the street name, so they are always there...
