Don't know if I missed something in the set-up but when I installed an AVIV z1 with a GEX P10ZMT, the only service I got was the traffic notification. I've reset the XM box, the AVIC, had the signal resent but to no avail. Toggling trough the AV button fails to bring up the unit. When I hit the library button, I can see the XM icon but its not active.
I did the install in a 2004 Cadillac SRX. HELPFUL HINTS: The metra GMX10 adapter needs to have the external amp wired to the power antenna wire on the AVIC. The Metra faceplate kit works well but the trim ring needs to be trimmed by about a 1/2". This moves the head unit out a bit and leaves room for the wires. The GM10 adapter can be screwed into the top of the opening (plastic tray) just below the vent ducts.
I haven't hooked up the reverese or VSS yet - perhaps at a later date.
Posted Oct 08, 2006 · 23:45 UTC#1
