itouch and no sound
By laflsyl10 · Feb 20, 2009in General💬 11 posts👁️ 1,214 views
Posted Feb 20, 2009 · 15:48 UTC#1
I cannot hear my itouch whenever it is plugged in.
I have the latest firmware update, it is also change into av setting. I can see everything about the song, the time also runs but i can't hear anything. Can someone help me out. CD, Radio, SD all work fine so not really sure what the problem is. thanks
Posted Feb 20, 2009 · 15:51 UTC#2
A: Did it ever work?
B: Are you using an ipod cable to the AVIC that has both USB and RCA connections?
C: Did you hook up the RCA jacks *and* the USB on the cable?
D: Did you change the AV1 input to say ipod?
Posted Feb 20, 2009 · 15:58 UTC#3
Connect the RCA's too.
Posted Feb 20, 2009 · 16:05 UTC#4
A. Never worked, just tryed today for first time
B. I have the white ipod cable connected to the black one connected at the end of the unit
C. What rca jacks,
D. I did change the input.
I'm getting a felling that i needed to connect something else...shizza, where is that rca jack your talking about, do i need to buy one myself
Posted Feb 20, 2009 · 16:21 UTC#5
there is your problem, the avic f's dont just use the usb cable, pioneer and apple both make a special cable that has usb, audio, and video on one end and a 30 pin dock connector on the other, the avic's use the usb to controll the ipod and use the av plugs to deliver the sound and video
Posted Feb 20, 2009 · 16:46 UTC#6
thanks for your help guys!, greatly appreciated!
Posted Feb 26, 2009 · 05:41 UTC#7
Where can i find this av plug online so i can purchase it??
Posted Feb 26, 2009 · 23:12 UTC#8
I bought one yesterday @ 6th AVE (at the store, not online) for $20.00
Posted Feb 28, 2009 · 08:10 UTC#9
I just did a hardware bypass. Prior to the bypass, both of my ipods worked like a charm, including video on the ipod (with the parking brake on). Now, I'm getting the same symptoms the original poster of this thread was getting. No sound from either ipod. I do have the right cable. I too am getting all the info about the song. I see the song playing and time ticking but no sound. Videos don't seem to be playing either, just a black screen (parking brake on or off).
The sound works for AM/FM and DVD. DVD is working while moving so the bypass worked. The Ipod icon shows up when hooked up. Just no darn sound.
I had this professionally installed and both the USB and RCA are connected and electrical taped up.
I did try the reset.
Could this have anything to do with moving the mute wire from the hardware bypass. I didn't touch any other wires but move the mute wire and ground it as well as ground the parking brake wire.
Any help would be appreciated.
Posted Feb 28, 2009 · 08:12 UTC#10
Did you bother to change AV Input 1 back to ipod after you reset it?
Posted Feb 28, 2009 · 18:34 UTC#11
Alright, I sorted it out. I think it's cuz my ipod was playing music and connected while I was resetting and changing the AV1 input. I disconnected it, hit reset, let the AVIC do its thing, changed the input to IPOD then connected and it all worked out. I wish I would have tried that first instead of tearing it apart and checking the RCA's lol.
