PANIC! I am unsure the 700BT will fit into my Explorer!
(2000 AWD EB edition V8 5L)
It cannot fit from the front that is for sure. The molded lip/frame is too small.
So I got the trim kit that allows you to install it in the back and has plastic side plates/brackets that hold it to the frame and you screw them into the radio.
I thought sweet that will work!
My problem is the front of the 700BT is too large as well from the rear! I cannot see a way to get this to fit in there without dremmeling the factory frame away! Then I have to be careful to leave a bit for the plastic brackets to hold on to...
It is the top and bottom. It is simply too narrow. Even the smaller very front of the 700 where it is beveled won't fit vertically.
The sides just fit. It is snug with the plastic brackets but I think that will work fine. This radio should fit but now I am scared I bought all of this for nothing, or I just cut out the frame on the top and bottom.
Damn I thought this stuff was standard, double DIN and all of that!
Ideas???
