Gracias! ![]()
Someone has the UBOOT.BIN AND UBOOT.CKS
someone? pleeeeeease
if you manage to get these files let us know. we could use them for additional hacks on this forum.
also to everyone else he deleted his my flash disk when he booted into test mode, reset his unit, and now cant get into test mode to copy the files back but can get into uboot menu but needs the 2 files he posted.
I brought the file testmode.exe?, where they found him?.
the uboot.bin must be in the same place where they found the testmode.exe.
try using the other uboot gps but it does not work.
bump!
I need these files as well (I think)! Tried about every other solution I can think of and when I run the uBoot test, I get "bad/ press any key to continue". Please help!
Here you go. Found I didn't need them in the end, when I did the WinCE upgrade, it fixed the uBoot issue I had.
http://users.tpg.com.au/mel4pau1/avic/uboot_f900.zip
I'll leave it there for a while but it's not a file sharing service, I don't have any accounts set up for that. Can't guarantee it'll be there in a month!
Hi this link is dead.. do you know where i can find these Uboot files?
thx
you dont want to mess w/ uboot.
you probably just need to re-do OS flash (winceimg.bin/winceimg.cks)
