Any way to delete the clock?
By superman8262 · Feb 22, 2009in Hacks/Mods💬 8 posts👁️ 1,007 views
Posted Feb 22, 2009 · 03:59 UTC#1
Is there a way to get rid of the clock period?
my car has its own clock already so its redundant to have it on the unit. to make matters worse, i read that the avic units has two clocks both with different times or something.
is there a way to lose it in general?
Posted Feb 22, 2009 · 09:10 UTC#2
the one showing in the map can quite easily beremoved.
Check the navmap800480.ui file.
Posted Feb 22, 2009 · 10:19 UTC#3
................ and just comment it out.
Posted Feb 22, 2009 · 10:19 UTC#4
Posted Feb 22, 2009 · 12:21 UTC#5
oh yeah
sorry :wink:
Posted Feb 22, 2009 · 12:50 UTC#6
You can also delete the clock in the A/v interfaces. In image.res in I believe the AV folder, you'll see a bunch of blue digital numbers. make them all black and there will be no clock.
Posted Feb 22, 2009 · 13:27 UTC#7
Hmm......... is it not just easier to comment it out?
Posted Feb 22, 2009 · 14:00 UTC#8
hmm so just find the clock and ; that mofo out.
then change the color in the AV. sounds good. ill try that out.
and thanks guys
ps. i love you all
