SOLVED!!! Iphone and f900bt problem
By stang88 · Feb 22, 2009in Problems/Troubleshooting💬 16 posts👁️ 2,238 views
Posted Feb 22, 2009 · 06:32 UTC#1
I can call out on this unit perfect. But if someone calls in the screen will show the name and number like its supposed to,but i cant hear the person and they cant hear me. if i pick up my phone i can talk to them thru it then without notice it will switch to the f900bt.
I have tried many different things and i am stumped. This is my only issue with this radio.
Anybody have an idea to the fix?
sure enough. upgraded to 2.2.1 and it works.. thanks for all the input guys!!
Posted Feb 22, 2009 · 06:57 UTC#2
Answer the call from the head unit instead of from the phone.
Posted Feb 22, 2009 · 12:46 UTC#3
i tried that...i have tried auto answer and still nothing.
Posted Feb 22, 2009 · 14:32 UTC#4
Just out of interest, does the mic work for VR?
Bad mic installation would cause this kind of issue..
You say they can't hear you, is that "can't hear you at all"? or "can barely hear you"?
Posted Feb 22, 2009 · 15:21 UTC#5
yes it works in vr. if i place the call it works perfect. The issue is incoming calls. the unit will not answer incoming calls right.
Posted Feb 22, 2009 · 16:06 UTC#6
what software is on your iphone? upgrade to 2.1 or later
Posted Feb 22, 2009 · 16:14 UTC#7
althought it shouldnt matter cuz my phone works just fine with other bt devices...
its a 2.1 unlocked for tmobile.
Posted Feb 22, 2009 · 16:23 UTC#8
try 2.2 software
Posted Feb 22, 2009 · 18:15 UTC#9
2.1 and 2.2 have worked just fine with my 3G and the F700BT, I've never had an issue with callers not hearing me.
Poor quality at times, yes, excessive road noise at times, yes, but no echo, and they can hear me.
Posted Feb 22, 2009 · 18:21 UTC#10
i guess im not seeing what 2.2 is gonna solve. the phone works fine on all other devices. i see nothing on pioneers website saying that the iphone needs to have 2.2 to work right. I guess i am the only one with an issue like this with an iphone?
Posted Feb 22, 2009 · 18:22 UTC#11
calling out is not an issue.. it works pefect, its the incoming calls that dont work.
Posted Feb 22, 2009 · 20:29 UTC#12
does your avic have 2.0 firmware with the bluetooth update this is a must? and unless you want to try 2.2, or try another phone,or try another avic, one is the problem.
Posted Feb 22, 2009 · 21:31 UTC#13
it says 2.0 on the box.. i havent verified on the unit tho.. what should it say on the unit?
Posted Feb 23, 2009 · 00:31 UTC#14
just checked.. the unit has the 2.0 update and the bluetooth update... still same problem.
Posted Feb 23, 2009 · 18:09 UTC#15
just talked to pioneer.. they seem to think its the unit. i have a new one coming today. I hope this fixes my problem.
Posted Feb 24, 2009 · 03:36 UTC#16
ok.. wasnt the unit.. still does the same thing. so i am upgrading to 2.2.1 tonight. i hope that solves it.
