possible sound mute mod
By paQ · Feb 22, 2009in Hacks/Mods💬 11 posts👁️ 1,407 views
Posted Feb 22, 2009 · 18:16 UTC#1
I find it frustrating that the AV sounds mutes completely when the navigation voice comes in.
Also the *ding* gets annoying after the first 8 times or so. A *ding* is nice when there were no instructions for the last 15 minutes or so...
Anyway.
I've spend some hours in the common ui files inside the data.zip.
In the settings.ui I found this bit:
As I read it it sets a value for the os_volume and its mute.
How about finding a mod that a third string is created during navigation, something in the region of:
if "!play command" SET sound.os_voume 80
(80 out of 255)
furtheron it says:
This all seems only aplicable on the soundsettingsmenus, nevertheless I think there are some useful strings in here to put in the override script...
I'm not a devver though :roll:
Any ideas? :idea:
Posted Feb 22, 2009 · 19:04 UTC#2
How dumb is this :lol:
It is an excisting setting! :idea::!:
Go to AV SOURCE
Hit the OFF button in the right down corner
press MENU
Go to SETTINGS
Go to AV settings
make sure AV1 is OFF, AV2 is OFF
Hit return
Go to AV settings
the first button on the second row displays MUTE.
ATT is for half muted
NORMAL keeps on playing (but can be quite disturbing)
the *ding* mod however, would still be nice to achieve :)
Posted Feb 22, 2009 · 19:25 UTC#3
Write this in your sys.txt. The ding should go away.
[sound]
ding=0
Posted Feb 22, 2009 · 19:26 UTC#4
that's it? :?
so if I write:
[AVIC]
work faster=1
Posted Feb 22, 2009 · 19:42 UTC#5
hahaha we wish
Posted Feb 22, 2009 · 19:58 UTC#6
that's it? :?
so if I write:
[AVIC]
work faster=1
HAHA brilliant! :lol:
Posted Feb 22, 2009 · 21:36 UTC#9
So did it work?
Posted Feb 22, 2009 · 21:56 UTC#10
[sound]
ding=0
If this works put it in sys.txt thread.
Posted Feb 23, 2009 · 12:12 UTC#11
Yes it sure works! 8)
(still working on the avic_go_faster=1 line ;) though)
also the ATT settings for instructions is a LOT better!
Still wanting a time-out for the ding...
for instance to only play the ding if the last instrucion >720 sec or so.
I remember quite some trips where I've spent hours behind the wheel, middle of the night, getting whoozy, and then suddenly "BEAR RIGHT"
Bear? where? what? :shock:
