Wierd hum from 12's
By skon1etzk0 · Feb 23, 2009in Car Audio💬 3 posts👁️ 1,556 views
Posted Feb 23, 2009 · 02:03 UTC#1
Need a tip from some audiophiles out there
I have two 12's in my car, and I have been hearing a loud hum from them intermittently. I have a feeling it is my head unit (which is being replaced with an AVIC this weekend :D ), but I am curious to know if anyone else has had this issue, and what was causing it?
Maybe that way while I am in there I can fix whatever else might be wrong.
Posted Mar 01, 2009 · 22:55 UTC#2
Installed AVIC, seems to be working ok now. Just in case however, I also re-stripped the cabling going to the amp and to the speakers. All seems fine now.
Posted Mar 16, 2009 · 19:45 UTC#3
Usually a hum is caused from having your wiring ran past a fuel pump or a distributor cap. Anything that will cause electrical interference will cause a hum. Invest in some shielded wire and that should fix the problem if it comes back.
