Ok I have a 90Bt and I have been trying to upload Splash screens for 2 hours and im getting really pissed. I have Sd Card(ScanDisk 4GB). I found a bunch of Splash screens I liked and then saved them in a PICTURES folder. I made sure they were all 800X480 and then placed the card in the unit. I keep getting the same damn message about the Picture folder.Getting really frustrated PLEASE HELP!!
Splash Screen Problem!!
Rename it "Pictures", not "PICTURES".
Just out of curiosity, why would that matter?
Windows doesn't care whether it's caps or not.
Tried that still nothing UHHHHHHHH
There was some speculation of the OS being case-sensitive a while back, but AFAIK it's never been confirmed, although a few months ago I cae across a guy whotried to change the data.zip and it wouldn't load because it was not written EXACTLY how it was supposed to be.
OP, try a USB drive.
I believe you can load then with a CD as well if everything else fails.
What kind of CD?
Just a normal CD that you would burn on you computer. Same method as SD.
Did you put the "Pictures" folder in the root directory of your SD card? Maybe you should also remove any other system files from the root directory just to be sure...
Did you try if the SD card is recognized at all?
Can a splash be done on the f700??
Yes
Can we have more than one image on the "Pictures" folder?
Yes
