windows CE is freezing when i run explorer any suggestions?
By untuned · Feb 24, 2009in Hacks/Mods💬 7 posts👁️ 1,176 views
Posted Feb 24, 2009 · 04:19 UTC#1
try to hack my unit today, was able to get into windows CE but when i hit start -> programs -> explorer it does nothing i waited like 30mins. anyone else have this problem?
Posted Feb 24, 2009 · 07:41 UTC#2
when it has finished loading, you'll see "OK" in the screen.
When you hit the screen, a green square shows.
On either moment you just close the screen with the X in the top right corner.
Does your CE freezes after that has been done?
(Also I don't think you'll see anything when you hit start>Programms)
Posted Feb 24, 2009 · 16:16 UTC#3
You need to keep trying to hit the x in the top right corner, it might take a few times of hitting the x but it will close that window, then you are in, Try using the end of a pencil to close that X
Posted Feb 25, 2009 · 07:37 UTC#4
Or you can use the stylus that came with the AVIC, (and is intended for small button play)
Posted Feb 25, 2009 · 08:56 UTC#5
Stylus? What stylus? Am I the only one not to have a stylus supplied with my 500?
Posted Feb 25, 2009 · 08:58 UTC#6
I'm not sure if you get them with the 500, I know my 90 came with a stylus.
Posted Feb 25, 2009 · 12:46 UTC#7
Hmm...
with the 700, 900 and 90 there's a stylus.
Also needed for proper calibration. (it even states that when calibrating)
