Hey guys,
So i've got the F500BT with ND-G500 amp and iPod cable. Since it is a "portable navi" it's installed a bit different than your normal in-dash unit. Instead of being wired into the car and driving the speakers, the AMP for this navi plugs in between factory HU and speakers. This way it can mute and pass navi instructions, ipod music to car's speakers.
BUT the harness it comes with - is the freaking weirdest thing i've seen. It has plugs that don't seem to match to anything. I went to local electronics store to look at Metra plugs - none of them seem to have same pattern. Not only that, but those that are avaliable from metra - have 6 pins or so, when these have no less than 8 on each. So i don't see how i can use any of the metra cables, if there are not enough pins in the plugs. (how HU send signal to 4 different speakers with only 6 wires?)
I've talked to local audio installer - and they guy told me that is is a wierd plug and he doesn't have any idea how to plug it in. He said they would have to cut the connector off the AMP harness and hard wire it to the the car.
Does anyone know if there is a special plug i can use, so i don't have to cut off the cables of the Pioneer harness?
My car is 2008 Toyota Highlander
Here is a pic of the three cables
