Bluetooth SOOO SLOW???
By Auhdabey · Feb 25, 2009in Problems/Troubleshooting💬 4 posts👁️ 925 views
Posted Feb 25, 2009 · 04:53 UTC#1
Is there anything I can do to speed up the bluetooth? Its so slow its almost impossible to use... The phone rings and when you touch the green phone button the phone stops ringing before the unit picks up.... Then if you go to make a call the music still keeps playing for about 5 seconds after the person picks up. When a call is coming in it says incomming call until the last ring when it tells you who is calling but by the time you click the green phone to answer it says missed call. The unit seems to respond soooooo slow to the bluetooth and I have no idea why. I am using 3.3 with a ATT Palm Centro. Is there ANYTHING I can do to speed this up? So that I can at least try and use it successfully?
PLEASE HELP!!
Posted Feb 25, 2009 · 06:00 UTC#2
which version do you have? did you upgrade to version 2.0?
Posted Feb 25, 2009 · 18:05 UTC#3
Yeah I have 2.0 and I believe the newest version of bluetooth RC3... :(
Posted Feb 26, 2009 · 09:03 UTC#4
i have that too. it's even worse when looking at video. then the unit doesn't even answers the call at all. and there is no way to move to the phone menu no matter how hard you try... also running all the latest patches / versions.
this is the reason to stop using it and now i only listen to podcasts via a old nano. but even with only this this the phone menu is slow.
