help on wiring!! 05 g35x
By jin22gt · Feb 26, 2009in Vehicle Specific Wiring💬 4 posts👁️ 1,048 views
Posted Feb 26, 2009 · 17:19 UTC#1
I need a wiring diagram for 05 g35x sedan.
Also where is the reverse wire and the vss wire?
will the bypass work even tho the vss wire is connected?
im trying to install the avic f90bt.
thanks alot
Posted Feb 26, 2009 · 23:12 UTC#2
2005 INFINITI G35 4DR SEDAN
WIRE COLOR POLARITY LOCATION
Speed Sense WHITE/GREEN (AC) RADIO HARNESS 2KPPM
Reverse Lights RED/BLACK (+) PIN 141 @ BCM
The BCM (Body Control Module) is in the driver kick panel.
Yes, the bypass will work if the VSS is connected.
Posted Feb 27, 2009 · 07:31 UTC#3
thanks for the info.!
Is it necessary to connect the vss wire?
Do you know the speakers wiring?
Do you have a G35?
Posted Apr 05, 2009 · 05:59 UTC#4
All the wires except for VSS, remote and backup match right up with the appropriate receiver wiring harness.
