Hi guys.. I've read a lot of these posts and I can't seem to find anyone that's having the same exact problem as me, so here we go:
Have the F900BT running in a 1997 Toyota Land Cruiser - 40th Anniv., plugged into stock amp and speaker system.. Unit started continuous reboot cycle a few days ago after months of decent (but slow) use on the original software. After checking connections to see if something was loose (to no avail), I looked online and found this site. (originally bought off ebay dealer, had installed at best buy)
Tried downloading and applying the 2.0 firmware upgrade. When I loaded my SD card and inserted it and cranked the engine over, it took like 200 reboots before the thing finally booted from the SD card. Almost like it didn't recognize it right away. Finally, went through the upgrade process in about 10 minutes, followed the reboot instructions and it was still continuously rebooting, but actually loaded the NAVI menu and all functionality ran great on 2 occasions - which tells me there's no hardware problem. GPS constellation, bluetooth, everything worked well - *once it booted up*.
So then I read about deleting the user files off the flashdisk as a potential solution to the continuous reboot issue and figured I'd try that next.
So this morning I downloaded the testmode file, unzipped it and copied the two folders (testmode and MiTACAP) to the SD card. Everything else on the SD card I moved into a folder I created called "Archive" just to get it out of the way. Loaded this card in, cranked er over and nothing. Just goes to that pioneer screen for about 10 seconds or so, goes blank, and then does it again. I did notice with the SD card in the slot, it does not "try to load into NAVI" (can't remember what the other message is - system loading or something)..
But, nevertheless, I just can't get the system to boot into testmode so I can at least look around, clear the flashdisk files - whatever. Any ideas on how I can force it to boot from the SD? Or is there something wrong with my SD card (it worked fine for the 2.0 firmware upgrade)... should I get rid of that Archive folder I created so the only two folders on there are testmode and MiTACAP?
I can't help but think this is completely software related because when the unit (once in blue moon) decides to boot up, it runs wonderfully until I shut the vehicle down and start her up again.
Ideas?
Thanks from a Noob
