New guy here lost with GPS issue
By psdmondo · Feb 27, 2009in Problems/Troubleshooting💬 4 posts👁️ 739 views
Posted Feb 27, 2009 · 18:51 UTC#1
Ok so I have a new F900BT installed and for some reason after I correctly hooked up the parking brake lead the GPS keeps cutting out and will not track my location and the red arrow just goes grey... any ideas? Thanks
Posted Feb 27, 2009 · 18:54 UTC#2
and sorry forgot to mention when I first turn it on I have a great GPS signal i just keep losing it.
Posted Feb 27, 2009 · 20:42 UTC#3
Did you also move the MUTE wire link this? original harness
346951676_CrMY8-L.jpg modified harness
That wire will also need to be grounded.
As for the GPS signal, is the antenna blocked by anything metallic above it, and is the antenna on the little metal plate that came with the unit?
is the antenna plugged in completely?
Posted Feb 27, 2009 · 20:46 UTC#4
Mute wire shouldn't have with his issue. Looks like a bad contact with the GPS antenna...
