On the back of the display unit, there is a yellow connector soldered down by 4 points to a circuit board where the RGB cable from the navi unit hooks up.
How do I know it's connected by 4 solder points ? because mine has snapped off. :(
Is this something that can be repaired ?
It was a clean break, none of the contact pins appear to be damaged.
Has anyone else had this issue ?
The connection on the RGB cable is SO strong, I think that's what caused the break. All the pressure was on the solder points.
Posted Oct 10, 2006 · 16:21 UTC#1
