Before i tried the Firmware update 2.0 - i was having some issues with the USB and SD being recognized when both plugged in. In the past 2 days it would recognize them but not play anything.
I decided to do the Firmware 2.0 update (i did the 1st firmware update with no problems).. I did the update and the TTS update but couldn't access the bluetooth update, the phone touch button didnt work. Then i noticed just about everything stopped working. On boot up it wont come off the splash screen unless i hit the menu button. I have no volume, there is a dvd that wont eject, the map doesnt come on, cant get to any of the settings menus, etc.
after trying the reset + eject button when it failed to produce any results; it eventually after 2-3x came up with a windows CE message stating that the application failed to launch, and option to restore factory settings. First i sad no.. but after no more progress, i eventually hit yes. I waited the thing out while i figured it was doing something, to only have the same results.
The only mod i have done is the bypass (wired).
I just redownloaded update 2.0 in hopes that there may have been corrupted data, and will now hopefully have a better install.
But if the next attempt doesnt work i am at a loss, and am requesting help from any of you may have come across this. If this is something i can fix by hacking, with your advice/scripts i should be able to get it.
