1st of all i tried searching and could only fine one unresolved mention of onstar and the Hardware Hack. So i apolgize ahead of time.
In my setup i'm using the GMOS-04 Adapter by METRA to adapt my Bose/Onstar equipped 2006 Trailblazer to work with my newly purchased F90BT
The GMOS-04 harness has VSS, P.Brake, Reverse, Mute built right into the harness and in the instructions says to just attatch them to the radio harness wires.
i'm thinking i need the MUTE in order for my onstar to kill the radio when the button is pushed.
Is there another wire i can relocate/use in that 4th position on the NAV harness (maybe one of the 8 wires on the power harness for speakers that i'm not using because the GMOS-04 uses RCA Outs?? can i remove one without messing up the head unit/is it the same gauge/connector?)
What should i do with the wires on the harness? if i'm supposed to ground the parking brake and mute(or whatever wire i end up using)...i'm assuming i don't make the connection for the parking brake wire between the radio harness and GMOS-04?
