Z1 backup camera!!
By Pedy1 · Mar 02, 2009in Problems/Troubleshooting💬 2 posts👁️ 938 views
Posted Mar 02, 2009 · 00:44 UTC#1
I recently installed the license plate backup camera onto my Z1. We screwed in the ground, And wired a cable from the camera to the unit (brown input). Now everything works meaning the camera, but it only appears when you press the "map" button once or twice (depending on what screen you are on), then you press the camera selection. Shouldnt it be where if you put the car in reverse then it turns on?
Also how can i switch it so i only see the camera, not the map also?
Posted Mar 02, 2009 · 03:02 UTC#2
Hook up the reverse wire to the Z.
