Need a bit of help with my 2002 Toyota Tacoma 3.4 liter automatic VSS location.
I found the general info of where the VSS wire is (it's the green/orange wire on the ECM behind my glove box) but have no clue which harness to tap into. When I removed the glove box and the plastic shroud behind it I see a group of 4 connectors high under the dash, and two connectors on the plastic piece that was directly behind the glove box.
I see a Green/Orange wire on both of these groups. Any clue on which one I should tap into?
Below is a picture of all the wiring harness connectors behind my glove box.. notice 4 plugs towards the top of the picture, and a set of two plugs on the lower right side. Anyone know which one has the wire I'm looking for? I see a green/orange wire in both of these groups.
Here's a closeup of the plugs towards the top.
Any clue on which one is the correct one?
PS.. can I just unplug these connectors to tap into the correct wire? I'm a little nervous becuase my air bag is right above al this stuff.
